Civil MAN - Burnt OUT CAB
Démarré par tiking, 21 Janvier 2019 à 13:48:46
tiking
I have been experimenting lately with different burnt out effects lately. As you can see in some pics I have tried simulating carbon fibers as they literally tear into almost thread-like material, by using disinfection wipes. It looks 'OK' but not quite perfect. I have added more modulation effects on the cab and more weathering on the overall cab and truck as a whole.
The right tyre is flat. It is difficult to tell with all the ashes surrounding it. And yes, my reference photo had a similar attribute. I know most would wonder why the right tyre did not get burnt to a crisp like the left tyre...
In most cases depending on the degree of the fire and where it was most intense. I have seen photos with similar attributes.
I think , I am satisfied with the results , especially, after taking some outside photos of the model. What do you guys think?
[/URL
[URL=https://public.fotki.com/tiking1970/man-burnt-out-cab/man-burnt-out-cab-18.html]
tiking
Citation de: Poseidon690 le 21 Janvier 2019 à 14:17:21
Hi,
Really realistic !
:Merci:Glad you like it. It's funny, because this was suppose to be an experimental build. But it actually turned out pretty good for me. :)
Very realistic!!!
Magnificent work!
tiking
tiking
Remove the background and it would be hard to tell it is a model kit and not the actual thing.
My only little 2 cents would be that the ground do not seem burnt as well. But I am not sure how it would be in a real truck fire.
tiking
Citation de: leup le 22 Janvier 2019 à 14:41:29
Thank you. In most cases yes, but depends on changes of weather and other elements. But I did add that effect, but probably not sufficient. Will add more distinct effect to it. Thank you.
Le 2tsch
Oh putain ! Mortel!
Very good job !the truck is so amazing ! :1erprix:
Civic'N'CRX POWER!!!
si ça vous dit de
tiking
Citation de: Le 2tsch le 27 Janvier 2019 à 10:23:08
Oh putain ! Mortel!
:Merci: Glad you liked it.
 :obsede:  :prosterne:  :aplausos:  :1erprix:
incroyable de réalisme ! ça demande un vrai sens de l'observation ! et surtout savoir reproduire !!!
tiking
Citation de: Jief le 27 Janvier 2019 à 18:28:22
I am happy that you liked it.  :Merci:
effectivement... bluffant  :number1:
tiking
Citation de: HiCksS le 28 Janvier 2019 à 12:11:57
:Merci:
